89 IROC 5.0 runs good when cold - bad when hot
Old Mar 10, 2011 | 06:12 AM
Lanstro's Avatar
Default 89 IROC 5.0 runs good when cold - bad when hot
I have an 89 IROC with 5.0 - have done a complete tune-up. Runs great when cold - start running a little rough when hot - if I re-start the car, it runs good for about 30 seconds and then starts running rough again....any suggestions? Could this be injectors?
thanks
Old Apr 2, 2011 | 11:28 PM
HorizoN's Avatar
Sensors, sensors, sensors.
Namely, idle air control, o2 (because it's the o2 sensor, damn it) MAF, and the like.
Old Apr 4, 2011 | 10:26 AM
GLENN M's Avatar
EGR that was my problem,same symptons
Old Apr 4, 2011 | 10:29 AM
HorizoN's Avatar
I'm not entirely sure how this affects things, but isn't the EGR only active during certain times? I think at WOT and idle, there is no recirculation of the exhaust gases AFAIK.
Old Apr 4, 2011 | 10:39 AM
GLENN M's Avatar
no its active once engine reaches around 120 degrees, under vacuum not wot,when they stick open a bit causes rough idle and drivability problems
Old Apr 4, 2011 | 10:41 AM
HorizoN's Avatar
Hmm, I can see how that would cause problems. OP should check that as well then, definitely.
Old Apr 6, 2011 | 07:56 PM
microkid's Avatar
March 2011 ROTM
Technical User
a stuck open egr will make engine sound like it has a radical cam and you wont have much vacuum for brakes. it would also do it all the time, not just when hot. describe the condition of rough. rough idle, rough accel, rough cruise? any smoke or smells? is the idle steady or does it jump around? i need as much info as possible
wicked94z28
Oct 7, 2011 04:48 PM
Lanstro
Mar 10, 2011 07:53 PM
MillerOnTheRadio
Dec 30, 2010 11:59 AM
aaron89
Mar 27, 2008 07:49 PM
johnson
Mar 6, 2008 09:52 AM
