88 iroc-z overheating problem
Old 05-15-2009 | 10:06 PM
i think its supposed to stick down and scoop air up into the radiator. thats how the one on my 93 is. it looks like u blocked off the avenue for the air to get to the radiator. u should find a stock one and fab it to be similar.
  #22
Old 05-15-2009 | 11:20 PM
bryan0609's Avatar
didnt i say earlier that i had ordered one and sent it back because i could fab on myself so yes i did look at it and if you have ever seen a 3rd gen before that sucks air straight through the bumper that flow directly into the radiator and the ram air and its is doing its job greatly i havent overheated yet since i put it in
  #23
Old 05-15-2009 | 11:37 PM
good deal. ha im not up on 3rd gens so when i looked at it i was wondering. got yer wheels back,,, alright. so it doesnt have to be so flexable,.
  #24
Old 05-16-2009 | 07:26 AM
blackz87's Avatar
Hope it works, the bumper inlet do not let in enough air and the air dam is located behind the radaitor under the car.It is not a flush mount per your pictures.
  #25
Old 05-30-2009 | 08:33 PM
camaro88iroc's Avatar
i have an 88 iroc and it runs hot all the time, so i think it is normal. don't worry
  #26
Old 06-03-2009 | 05:09 PM
sammycamrestorer's Avatar
Also if you haven't already looked. If you pull the radiator shroud off and look between the radiator grill and the ac and oil cooler there might be tons of debris lodged in there causing it to overheat. These cars and the corvettes are alike. They are road trash suckers. I had this same problem along time ago and found out after I had replaced everything that had to do with the cooling system that all it was was built up leaves, trash, sticks and a bird nest!. Cleaned it out and wallah!
  #27
Old 06-03-2009 | 05:13 PM
djs383's Avatar
Also, I don't know if its been mentioned or not, but put a mechanical gauge on it. The sending unit style gauges are not something I make a high wager on at the craps table with......
  #28
Old 06-09-2009 | 11:22 AM
draggo144's Avatar
Where did you find the stock replacement air dam?
  #29
Old 06-09-2009 | 03:20 PM
mighty mike's Avatar
junkyard. best place
  #30
Old 04-23-2012 | 10:08 PM
Paul86iroc's Avatar
I had the same problem with my 86 iroc 305 carbed. I had an electric fan then switched it out for a big block flex fan. Now it runs at 100 on the street at night and 160 on a hot day.
