87 blower and NOS
Old Dec 18, 2006 | 05:44 PM
Monedogg's Avatar
Default 87 blower and NOS
Ok i have an 87 z28 with a carb.350 and i am going with a blower and NOS so i was woundering if there were do's or donts that i should be aware of and what cam and headers would go with this setup aswell thanks in advance for all the input
Old Dec 18, 2006 | 09:55 PM
FlufyTiger's Avatar
Default RE: 87 blower and NOS
You're gonna want a cam with good durations, as much lift as you can get without compromising your valves, and no overlap (since you are going with forced induction, you don't need any exhaust scavenging, and overlap would just blow air and fuel out the exhaust. You'll also wanna watch your compression ratio, as the blower and NOS will lower your usable compression on any given grade of fuel significantly. I would try to keep her right around 9:1-9.5:1 for pump gas. If you have a Sunoco nearby, you might see if they sell 98 octane (it's street legal around here, dunno if it is where you are.) If you can get that, and have it in the car all the time, you could probably go with 10:1 or maybe even 10.5:1, and you'd get a hell of alot more power out of that, but you'd also be spending a lot more on gas. Not that you should be worrying about fuel economy with a blower anyway, but I'm throwing it in there just in case. Also,if you give us some more stats on the engine, you could get a more specific cam recomendation.
Old Dec 20, 2006 | 11:18 AM
Monedogg's Avatar
it just a stock 350 nothing else yet anyway
Old Dec 20, 2006 | 09:27 PM
6292Z28's Avatar
Are yougoing to usea roots or centrifical charger?
Old Dec 22, 2006 | 10:11 AM
Monedogg's Avatar
centrifical charger,
6292Z28
what are you running in your car, and are you picking the front tires up off the ground?
BIGTHUNDER
Aug 13, 2014 11:27 AM
JakeYeah
Nov 9, 2012 11:14 PM
Kevin_B.
Apr 16, 2010 09:30 AM
70_boosted
Jul 7, 2007 10:43 PM
Jimbo
Nov 7, 2006 01:38 AM
