85 starting problems
#25
chances are theres a wire that is corroded internally or a loose connection somewhere. typicly well the volts are that much lower when there is no load on them, then there wont be enough amperage to fire the injectors. do you have a wiring schematic? if not, get one, and take apart the harness. could have happened during the swap. wires usually dont take kindly to being moved after sitting in one spot 20+ years
