700r4
700r4
hay have one more question if u get a 700 r4 out of a 85 or older camaro that is non electric can u use the lock up converter or do i need to get another one and what do i need to hook it up to my 91 camaro
i went to carb on my 1992 rs and i just installed a vacuum switch to control lock up. was easy to hook up IF you have the correct solenoid in the trans. here is a link to thirdgen that has mine and others in it.
http://www.thirdgen.org/techboard/ca...up-budget.html
