350 electrical problem and plugs question
ok i know my freezeplugs are gone to hell so i need to replace em and i know i need brass ones and i know i could do the labor myself but if i was to hire a mechanic how much should i be expecting to pay???? i have so many wires that are not even supposed to be there and most of them are cut or not connected. im not good with electrical except hooking up a bad *** sound system so how much money should i expect if i was get allthe electricalfixed??? thanks in advance
RE: 350 electrical problem and plugs question
Ok what year is your car? get the wiring diagram for it,may have to search the web. go to a junkyard and find the same car and take the whole harness. If you can do a system you can rewire a car. on 90% of the wires they can only hook up th the plug that fits..
You'll have to get the wireing diagram, they are all color coded. that will tell you what they went to. Do a search on here and see if anything comes up, if not post a new thread asking if anyone has one.
Thanks ,yep I'm in there. I looked on the net for the diagram but there were none posted up. somebody on this site should have one that they can scan and email.
https://camaroforums.com/m_66585/tm.htm Thanks and good luck......I'll keep searchin to see what I can find.
