305tbi to 305 tpi question
Old Sep 16, 2010 | 02:03 PM
Badrs2810's Avatar
Default 305tbi to 305 tpi question
I know this has been asked I'm sure, but I don't have time to look it up, so please bare with me. If I wanted to find and replace my 305 tbi with a 305 tpi, other than the motor, what do I need to hook it up and run? My camaro is a 92 rs if that helps. I don't have a lot of time or money being this is my daily driver, I just like the tpi better, little more power better looking and same amount gas mileage, thanks guys
Old Sep 16, 2010 | 07:41 PM
microkid's Avatar
March 2011 ROTM
Technical User
you would need the intake from an 87 and up 305 tpi. you will need the wiring harness, ecm, and the fuel pump. i think the stock gauges will work with the ecm swap. you can also use the same parts from a 350, but you will need 19lb injectors and the chip for the 305
James Glenn
Mar 11, 2014 05:07 PM
gbettner
82-92 V8 Tech
13
May 3, 2013 12:03 PM
89camarors305
May 10, 2009 11:34 PM
missmy72ss
May 8, 2008 09:49 PM
KRobbins
Jul 27, 2006 11:21 AM
