3 bolts till my engine and trans are out, i cant wait!
Old Sep 20, 2010 | 05:14 PM
big greg's Avatar
ok so the cam that was in my car has a big cross on it, followed by 8838 on the other side, h3 a little farther down,anyone know what cam this could be?
Old Sep 20, 2010 | 05:24 PM
Jr. Mechanic's Avatar
August 2009 ROTM
NO! That cam is wrong in every single way... First off its a mechanical flat tappet cam... Your TPI has an OE hydraulic roller cam. Second, it's WAY TOO BIG! I don't know if you have a 305 or 350, but either way it's much too aggressive as it sounds like your motor is stock. That cam is designed for oval track racing where the RPM's never drop below 6k. It WILL NOT work with your induction system, nor your heads, torque converter, OD and lock up transmission, or anything else in your combination for that matter.
Old Sep 20, 2010 | 05:43 PM
big greg's Avatar
my car has been monkey'd with, it has a flat tappet cam and lifters, its a 350, and i am putting 10;1 pistons back in it, plus its a t5 trans
Old Sep 20, 2010 | 05:45 PM
big greg's Avatar
i am wondering what was in my car as it sits? i think i will take it to a local speed shop and ask them what the specs are if they can tell by the numbers. and the tpi ran this just fine, i also figured i would have to get the computer reprogrammed
Old Sep 20, 2010 | 07:59 PM
August 2009 ROTM
Doesn't matter, that cam is still too big for a mostly stock 350. You would need at least 12:1 compression and race fuel to run that cam, as well as stronger internals and way better heads. Then you still have the problem with the TPI. You would have to scrap it and run a carb'ed setup. It's not as simple as reprogramming the ECM.
At this point you're then making enormous amounts of horsepower, have 5 grand into the engine, and need to get a new transmission, rear end, beef up the unibody, and it still won't be streetable in the least.
You need a much less aggressive cam.
Old Sep 20, 2010 | 08:07 PM
microkid's Avatar
March 2011 ROTM
Technical User
yep, that cam is race only. a co-worker of mine runs on similar in his 358 sprint car. it never sees revs below 6500 and has an individual throttle body fuelie setup. im running tpi with a 383 stroker, but i have large enough injectors and an adjustable fpr to help. i know its going to run like crap until i have the computer completely remapped. the ecm can only compensate for so much
Old Sep 21, 2010 | 12:02 AM
big greg's Avatar
I see that now, but the cam I pulled out of it seems pretty stout, I'm hoping I can get some specs off.it to see if I should run that with the 1.6s, and sub frame connectors are goin in right after this, trans will be upgraded after I blow this one lol
Old Sep 21, 2010 | 12:36 AM
big greg's Avatar
So would some 333882's be a little better then the stock heads I have now? And by the way thanks for putting up with some of.my.stupid questions lol
Old Sep 21, 2010 | 08:25 PM
big greg's Avatar
Ok I found a nice crane energizer hydraulic solid cam, 272-h10 454 lift 216 @.050 272 advertised, 1600-5400 rpm range, matched with some 9.5:1 pistons, and 1.6 rockers, does this seem better?
Old Sep 21, 2010 | 10:43 PM
  #20
August 2009 ROTM
Yes! That's a MUCH better combination. However the 1.6 rockers won't benefit you at all if you end up using the stock swirl port heads. You'll probably lose quite a bit of top end due to lack of flow.
