02 sensor placement?
Old Oct 25, 2012 | 12:44 PM
juice+'s Avatar
Default 02 sensor placement?
I have an 87 irocz tpi, i swapped the 305 for a 350 and put some headman street shorty headers on it. Everything is back together and runs good. One thing i forgot to do was weld in a bung for my o2 sensor. So i think i need the o2 sensor for the car to run properly. My question is, if i need the o2 sensor where should i put it? i think im gonna have to take the driverside header off to make it easier to weld in the bung. Any thoughts or suggestions?
Old Oct 26, 2012 | 06:35 AM
torque_is_good's Avatar
in the collector but be sure you mark it up so where you install it you have clearance when the engine is installed
Old Jan 24, 2013 | 02:36 PM
birdman11's Avatar
As close to where the stock one was on the original manifold. If you weld it in too far away down the exhaust,then you may need to buy a heated type o2 sensor or you will get a code 13. The stock type sensor may not get hot enough being that far away.
3rdnfnlbst
Nov 1, 2014 07:08 PM
Tomg303
Sep 6, 2012 05:52 PM
Dcapper81
70-81 Transmission & Differential
Mar 24, 2012 12:24 PM
Josh40601
Nov 22, 2010 04:53 AM
buckmaster
Aug 17, 2007 09:34 AM
