True or False
no thats incorrect, you just need to unbolt the trans from the motor itself and disconnect the driveshaft.you wont be able to use regular jacks as you would need one more heavy duty to give you more clearance to take out the trans from the bottom of the car
I've removed my trans twice without having to pull the entire eng/trans. It was easier for me to get to the top bolts from the top. I laid on a piece of plywood placed over the upper plenum. I think you might be able to reach them from the bottom by using a really long extension. HTH
