Starts than cuts out!
Old Mar 18, 2008 | 02:01 AM
sewerrat's Avatar
Default RE: Starts than cuts out!
Are you sure yours isn't MPFI? If it's original it should be and checking the fuel pressure is quite easy.The test port is at the rear of the upper intake plenum with a cap. It's kinda hidden but it's there.The test gauges aren't that expensiveif you can't borrow one.Do you have any engine codes?
Old Mar 18, 2008 | 03:43 PM
Camaro4life90's Avatar
alright than it probalby is MPFI if they come stock like that. No, no codes thats whats so strange about this I believe the mechanic got one code at some point at least thats what he said. It was for a MAP sensor which has been replaced now and still runs the same. Hasn't gotten anymore more codes though.
Old Mar 19, 2008 | 02:36 AM
sewerrat's Avatar
As Pete suggested, have your mechanic check the fuel pressure regulator. He can do a quick check by removing the vacuum hose going from the fuel/reg to the back of the throttle body. Have him test it with a handvacuum pumptesterto checkfor leaks. But if fuel seeps out of the vacuum hose when removed then it's clear that your fuel reg. is leaking and allowing the extra fuel into the intake manifold for the rich condition.
Old Mar 20, 2008 | 07:03 PM
Alright I think the mechanic found the problem it is the distributor its bad they tested it and the pick up coil wasn't responding. I will change it out soon once I get some money and let you all know.
Old Mar 31, 2008 | 10:58 PM
Alright all here's the latest update I put in the new distributor and the car will start and idle now so thats great news. But still cuts out when I hit the gas so its still pig rich. But I am lookin into it let you know when I figure it out.
logansz28
Sep 13, 2008 12:44 PM
biohazard
Jan 4, 2008 03:20 AM
wvblair
82-92 V8 Tech
Oct 11, 2007 01:40 AM
I_NEED_A_CAMARO
Oct 2, 2007 10:40 PM
