Starting issues
Old Feb 8, 2009 | 10:12 AM
trevora42's Avatar
Default Starting issues
so y 1990 rs camaro wont start. i went outside to leave and i turned it over and it acts like it is in gear and u try to start it...nothing happens.....all my lights work good...i think it is something to do with the chip or the computer ..can anyone help?
Old Feb 8, 2009 | 10:29 AM
Saint_Ali's Avatar
does the starter itself crank over ? just because the lights work doesnt mean the battery is good, it only takes 1 volt to use the lights, but you need at least 11 volts to start the car
Old Feb 8, 2009 | 11:28 AM
trevora42's Avatar
the key will turn but nothin... the battery is definetly good it has 13 volts and its recently new ...when i turn the key its the same way as if the car was in gear and u tried to start it.
Old Feb 8, 2009 | 11:48 AM
trevora42's Avatar
i have spark and my fuel injectors are good..
Old Feb 8, 2009 | 12:09 PM
Saint_Ali's Avatar
spark isnt an issue here.have you replaced the ignition switch yet ?
Old Feb 8, 2009 | 11:02 PM
1990CamaroRS's Avatar
Fancy Sparkle
does it fire sometimes and other times not start at all??
Old Feb 9, 2009 | 10:33 AM
trevora42's Avatar
yes it used to sometimes fire now nothin im pretty sure its the ignitoion switch or something with the computer not being able to read the VATS and i was going to bypass the VATS and hopping that will work befor i replace the ignition.
Old Feb 9, 2009 | 10:39 AM
Fancy Sparkle
have your starter checked. it could just be the starter motor has gone bad
Old Feb 9, 2009 | 06:54 PM
trevora42's Avatar
i removed the starter and took it too kragen it passed 3 times so i think it is the ignition lock cylinder needs to be replaced
bansheeboy261
Jun 19, 2010 09:21 PM
rolltide
Jul 21, 2009 07:44 PM
Saint_Ali
Dec 19, 2008 06:50 PM
My89Iroc
Dec 14, 2008 11:02 PM
jdubs1813
Apr 14, 2007 01:18 AM
