Rocker Torque Specs
Old May 2, 2011 | 12:12 PM
Devoult's Avatar
Default Rocker Torque Specs
Hey everyone again. i had another question. does any one know the torque specs for the rocker arm bolt. i'm not talking about the stud that the rocker sits on. i've tried looking all over the net and i could only find the specs for the stud.
And i'm also assuming that the valve has to be closed when your torquing down the the nut.
Old May 2, 2011 | 01:03 PM
Devoult's Avatar
Ok, after more digging i think i was able to find the specs i need. what i got was 11lb ft + 30 degrees after that.
Old May 3, 2011 | 05:05 PM
Devoult's Avatar
Ok, well i just heard from a friend what i might have to do is tighten down the rockers a little bit and then fire up the engine and tighten them down until they stop ticking and then do a additional quarter turn. is that what i have to do or do i just do the 11lb ft plus 30degrees??
Old May 6, 2011 | 12:05 PM
Devoult's Avatar
well i pulled the push rods out last night and there where none bent. i rolled them on the counter is how i checked them. i think i may have tightened them down to tight and made them start ticking really really bad after a short drive.
Tipsy
Jun 9, 2014 08:06 PM
Chevynutz
Feb 25, 2012 11:44 PM
Freeksen
Jan 28, 2011 04:02 AM
95z281LE
Jan 15, 2008 06:11 PM
SickSickSick
Jun 25, 2006 01:07 AM
