My 90 Camaro Dies Off
Old Jan 7, 2009 | 02:33 PM
neversave's Avatar
Default My 90 Camaro Dies Off
Turns on great with no problems, Fuel pressure ok, compression ok, and spark ok. Changed MAP, but didn't change anything.Shuts off when it gets hot. Help Please, I feel that i tried everything.
Old Jan 7, 2009 | 02:44 PM
rockin85's Avatar
Default RE: My 90 Camaro Dies Off
can you give more info about the engine and fuel injection? and how long has it been doing this? how long does the car stay on before shutting off? it could possibly be a computer problem, or your fuel pump might be starting to die out, or your gas could be bad. i dont know but what i would do is find a way to plug into acess port and see if any codes come up.
Old Jan 7, 2009 | 04:02 PM
neversave's Avatar
its been doing this for about a month, i think it has a 305 engine not completly sure. its a v6 FI, runs fine when the engine is cold, its when it gets hot that it shuts off. im able to turn it back on fine for a couple sec. but then it just shuts off.
Old Jan 19, 2009 | 06:15 PM
neversave's Avatar
i was told that it could be the coil, i changed it but still no fix. i took of the ignition module and old heat compound off it. could this be a problem??
Old Jan 19, 2009 | 09:59 PM
Lithorian's Avatar
sounds almost like as soon as it hits closed loop it dies. pull the codes from the computer. something is probably stored.
Zach Johnson
Sep 3, 2015 05:53 AM
grapeape1
Jun 28, 2014 03:12 PM
roughneck
Feb 13, 2014 10:17 PM
lovehatecamaro
Apr 13, 2010 01:10 AM
RFxCamaro
Jun 27, 2008 06:43 AM
