Looking For Some Info
Old 11-02-2010 | 09:46 AM
camarogurl843's Avatar
Default Looking For Some Info
I have recently replaced my fuel pump, fuel sending unit, fuel injectors, fuel filter and fuel pump relay. The car would run for a couple days and then the fuel pump would quit pumping. Then if you wait a few days the car will run, but now the pump will not turn on. Any advice? I'm so frustrated and confused
Old 11-02-2010 | 09:50 AM
what fuel pump did you use? check fuel pressure, the cheaper ones are prone to early failure.
Old 11-02-2010 | 09:56 AM
I replaced the fuel pump with an AC Delco
Old 11-02-2010 | 10:03 AM
thats a good one. i would suspect and test the ignition switch. check all fuses for piece of mind, check for spark at the plugs. it is turning over right, just wont startup and run? what yr camaro?
Old 11-02-2010 | 10:09 AM
I have spark, I have checked the fuses, I have checked just about everything I could think of. The fuel pump isn't kicking on. It is a 92
Old 11-02-2010 | 10:25 AM
need to find out if your getting power to the pump, is there power to the relay? found this but i dont know how much truth there is to it. Check behind the battery. You will see something bolted to the fender with 2 wires coming out of it. UNCLIP that assembly and you will find the fuse.
Old 11-04-2010 | 03:44 PM
I am getting power to the back of the car where the fuel sending unit plugs but nothing after I plug it up. I dunno what else to check.
RodneysPhoto
03-28-2011 02:44 PM
Skidoo03
10-18-2010 07:39 PM
82indy
01-08-2010 09:01 AM
Homestar1217
06-27-2009 09:37 PM
vinnyboombots
04-04-2009 04:14 AM
Quick Reply: Looking For Some Info
