Help
Old Jul 13, 2009 | 12:02 PM
prix87's Avatar
Default Help
I have a '85 camaro. 5spd 2.8 liter mpfi. Check engine light came on. Car will hold idle after giving it gas. Tried my obd scanner and paperclip grounding. Won't read any codes. Any suggestions??? Is the ECM bad? car was running fine all up untill now.
Has a 2.8 out of 87 firebird. with 85k on motor and 135k on body. new distributer, cap, rotor, plugs, fuel filter pcv valve, waterpump, timing gear/chain. timing was set. i'm at a loss here
Old Jul 13, 2009 | 05:13 PM
Saint_Ali's Avatar
are you sure you did the paperclip trick correctly ? weird that the light is on but wont show any codes
Old Jul 13, 2009 | 10:51 PM
prix87's Avatar
I've used my obd scanner successfully on the car before. Now nothing gets the computer to respond to that port. Any clue???
Old Jul 15, 2009 | 12:48 AM
neversave's Avatar
take it to a local shop, they ussually dont charge for pulling codes and have great scanners
