Check Engine Light
I was giving you a chance at proving you were just frustrated, but In actuality your acting like a complete **** head,
I've read and understood my chiltons under all models, they give you full specifications on which engine needs what to be fixed, no its not as complete as a shop manual, but If you understand the troubleshooting tables it's a pretty helpful book
I got my RS in 07' and yes I used a chiltons and the "Interwebs" mainly TGO to solve my problems
The reason I ask for more codes is because you could have an underlying code ie ECM failure that would surpass a map sensor code
You need to take a step back and accept the help you are looking for, if you weren't looking for easy answers your head would be in that chiltons and not on here, that's what sharing this information is about, easy answers, but you still need to understand how and why your car is doing what it is, not just throw the part on and hope its fixed
this thread has not gone to waste , as my gen 3 has the very same fault , so i have pinned out the eobd plug and come up with codes 33 and 34 both relating to map sensor . i have checked all vac pipes and they seem fine so i think i will try a map sensor ! i also have a chilterns manual but its for a chevy day van but the engine is the same as far as i can tell , its been most helpful apart from components being in different places . so hopefully between chiltern and this thread i may have fixed my gen3 so thanks caveman305 most helpful !..
