abs inop light
Old Dec 7, 2008 | 04:52 PM
camaro girl's Avatar
Default abs inop light
does anyone know why the abs light goes on and how to fix it? i have a 97 rs, the light only comes on occassionally and if i turn the car off and start it again the light goes off. i used to have different size tires on the back but now they are all the same size. thanks for your help
Old Dec 7, 2008 | 05:47 PM
Default RE: abs inop light
The ABS light goes one for a number of different reasons. The best thing is to get it scanned and see what the complaint is. When the ABS light is lit, the ABS is shut down.
Old Dec 7, 2008 | 06:03 PM
MadMikeZ28's Avatar
What Pete said
Also did the light come on with the different size tires? Was the size difference a lot? It could have been calibrated for the different size and now the computer knows there is a difference in the readings between the front and rear wheels. But a scan will give the correct answer.
Also, for future refernce,you might want to post your questions on your car in the 4th gen section.
Old Nov 8, 2010 | 08:37 PM
sebastianwebber's Avatar
Grounding and some electrical issue might need to be checked, or replacing the whole ABS Control Module would do the fix.
Old Nov 8, 2010 | 09:24 PM
Buffalo02Z28's Avatar
My ABS hasn't worked in seven months.
Old Dec 6, 2010 | 02:02 PM
Jus22tin's Avatar
I know this is an old thread but if anyone has an abs inop light on, you could try what I did after a little research I found that the most common reason that this light stays on is because the bulbs in the third brake light in the back are burnt out. I had this problem, and after reading about this checked my third brake light and shore enough it was out, went to Advance Auto got the bulbs, replaced, and now no more light! Hope this helps someone with the same problem. Oh yeah this is a 4th Gen fix.
Bad2TheRooTS
Jan 14, 2011 11:02 AM
hpd218
Aug 24, 2010 12:05 PM
viciouZ
Aug 30, 2007 10:23 AM
Dan_95_Z28
Dec 10, 2006 08:04 PM
Skiwee10
Aug 31, 2006 12:54 AM
