28. to 3.4 swap response.
Old May 8, 2011 | 06:42 PM
darkdesirecamaroman's Avatar
Default 28. to 3.4 swap response.
I read the post earlier of 2.8 to 3.4 swap. I was wondering if i swapped without switching the chip, what problems will i have?
Old May 8, 2011 | 07:30 PM
H2C's Avatar
H2C
It will explode
Old May 8, 2011 | 07:55 PM
cbr600rx7's Avatar
It will not explode however it will not run good. Fuel and timing will be off.
Old May 8, 2011 | 09:55 PM
H2C's Avatar
H2C
Are you sure? i thought there would at least be some sparks or something
Old May 8, 2011 | 11:21 PM
On that note, will any Camaro 3.4 chip work, or are some years better?
Old May 22, 2011 | 04:13 PM
Viridian1991's Avatar
If you're swapping but keeping a V6, look into the 4.3 motors out of the SS S-10s, that's the project I'm doing right now
Old May 22, 2011 | 04:30 PM
ATM's Avatar
ATM
This sort of thing makes me want to cry.
Old May 22, 2011 | 11:14 PM
You're in a V6 tech section man, I'm using mine as a daily driver so I need to keep up with emissions and can't afford an LS1, so chill.
Old May 23, 2011 | 04:11 AM
ATM's Avatar
ATM
Oh, it isn't the V6 engine that makes me want to cry. It is all the work involved in going to a DIFFERENT V6 engine that makes me want to cry. I suppose that if you've got a lot into the car then it could make it worth it.
Old May 23, 2011 | 06:14 AM
I can't speak for him, but i got mine for $350 from a mexican guy in the process of being deported. AND he was an alcoholic, so the damage from drunk driving was terrible. When I bought it it had no key, I didn't know if it started or not. Got a key made, she started right up. Had to put 3 grand into her for inspection. Then I replaced the entire front end, and gave her a fresh paint job. Did all this at my garage. So yeah, I'm damn proud of this car, I love driving it every day, and want better power with decent gas mileage. V6 swap only requires comp change and wiring harness as far as I know.
