28. to 3.4 swap response.
I read the post earlier of 2.8 to 3.4 swap. I was wondering if i swapped without switching the chip, what problems will i have?
It will explode
It will not explode however it will not run good. Fuel and timing will be off.
Are you sure? i thought there would at least be some sparks or something
On that note, will any Camaro 3.4 chip work, or are some years better?
If you're swapping but keeping a V6, look into the 4.3 motors out of the SS S-10s, that's the project I'm doing right now
This sort of thing makes me want to cry.
Originally Posted by ATM
(Post 539027)
Oh, it isn't the V6 engine that makes me want to cry. It is all the work involved in going to a DIFFERENT V6 engine that makes me want to cry. I suppose that if you've got a lot into the car then it could make it worth it.
(Post 539137)
