2.8 internal balance question
Old Jun 28, 2007 | 02:16 AM
sewerrat's Avatar
Default 2.8 internal balance question
I have an 88 2.8 MPFI, 5spdthat burns almost as much oil as gas LOL. After searching locally for several months I came across a decent running 2.8 MPFIfrom an 85 firebird but ismated to an automatic trans. I've read were 88 and up were neutral balance engines and 87s and down were externally balanced. Can someone tell me if this is true and will I haveimbalance problems using my 88 manualflywheel onto the 85 engine?My future goal is to swap in a TPI v8 when a good donor becomes available as well as funds. Thanks for any replies.
Old Jun 28, 2007 | 03:31 AM
1985RS's Avatar
Default RE: 2.8 internal balance question
there shouldnt bea problem swapping engines. if what you say is true about the balancing, there may be a slight bit of a vibration, but nothin to be concerned about. and if memory serves me correctly, those 2.8's are not the smoothest running engine out there tobegin with....
KcLive
Sep 16, 2012 04:29 PM
Phalen123
Aug 26, 2010 09:19 PM
kyleag89
Oct 6, 2008 08:58 PM
imtico
Oct 23, 2007 11:06 PM
digitalrebel
82-92 V8 Tech
Aug 23, 2007 10:30 AM
