camber adjustment
camber adjustment
i was womdering if you can adjust the camber ( from positive to zero camber ) on the 89 camaro's (RS). my camaro has a bad positive camber and its chewing away at the tires. thanks in advance for the help!!
RE: camber adjustment
yes you can....some alignment shops will not do it since it is not manufacturer "spec" but you can easily go to0.5 to 1 degree NEGATIVE camber. just make sure both sides are negative and not one side positive and one side negative as it'll drift
Make sure you get a printout of the specs when done and make sure that the camber is negative, and the caster and toe are in spec.
