New project.. No air?
Old Dec 12, 2012 | 10:24 PM
OrangeRS's Avatar
Default New project.. No air?
Hi recently got a 92 camaro. My ac an heater quit blowing air. Seems like none o the speed settings work at all. I changed the blower motor and still nothing.. Can anyone help please
Old Dec 13, 2012 | 12:12 AM
BasicConcepts's Avatar
Technical User
Sounds like maybe the resistor, its usually pretty easy to tell if there blown but first make sure your getting power there before spending money.
Old Dec 13, 2012 | 07:15 AM
OrangeRS's Avatar
Could you tell me where the resister is located?
Old Dec 13, 2012 | 07:53 AM
Edwardgp's Avatar
Welcome, I could tell you but can't explain things very well. What I have done is bought every book I could find on my car. Then I would look up the wiring diagram and hunt the resister down. On my car it is under the hood mounted in the heater box right next to the blower motor.
Old Dec 13, 2012 | 08:11 AM
If it was the resistor, your fan would still work, but only one or maybe two speeds.
To answer where it's located, look at the video.
But since it's not working at all, you need to do some tracing with a meter or test light to find where the loss is at.
Obvious one, have you checked the fuse? Is there power at the harness on the resistor? Is there power at the switch?
skyfreakmg
Dec 12, 2011 10:38 AM
onlymesince1989
May 6, 2010 07:00 PM
may83
Aug 10, 2007 04:36 PM
wizard
Aug 8, 2007 08:40 PM
