My 86 Sport coupe project thread.
So i figured its about time i start a thread on my 86 Camaro before i get further into it. I bought it in the beginning of July this year for 500 bucks not running and sitting for 3 years. I made some progress in the few months I've had it so I'm gonna post what Ive done so far and then add on from there. Hope you enjoy.
The car before i picked her up at the previous owners house. http://img41.imageshack.us/img41/741...44015large.jpg Picking her up. http://img339.imageshack.us/img339/5...7047501759.jpg At my house. http://img171.imageshack.us/img171/2...7447511759.jpg http://img683.imageshack.us/img683/2...7847521759.jpg I popped in a battery and she started right up. Ran very rough and smoked out the tailpipe. After pulling the valve covers, i found some yummy cake mix. http://img220.imageshack.us/img220/6...8000501759.jpg http://img830.imageshack.us/img830/7...0000551759.jpg |
Great deal. How's the interior?
All the interior needs is a headliner and a very small tear stitched up on the bolster seam of the drivers seat. The dash isn't cracked nor any of the plastic pieces.
The engine spun a bearing a few weeks ago and since then i started to pull it to swap in a 350. I got the engine out and the front end mostly disassembled for rust removal and paint/undercoating. The battery tray had it the worst, but i ordered an OER replacement tray that should come sometime next week. The lower radiator support also had some rust, so i ground it down and put on a few coats of rustoleum. Im gonna hit it with rubberized undercoating after the rest of the bay is clean and ready for paint.
http://img847.imageshack.us/img847/6...0911131300.jpg http://img692.imageshack.us/img692/2...0911131301.jpg http://img3.imageshack.us/img3/182/090911131401.jpg http://img339.imageshack.us/img339/4...0911131402.jpg http://img856.imageshack.us/img856/6...1011133400.jpg http://img856.imageshack.us/img856/6...1011133400.jpg This was done today: http://img98.imageshack.us/img98/7591/091111160801.jpg http://img88.imageshack.us/img88/4006/091111163201.jpg http://img714.imageshack.us/img714/361/091111163202.jpg I just have to re-weld the end pieces where the lower support meets the rest of the frame on both sides. I also had to cut out some of the passenger side frame behind the headlight as it was just eaten away. I'm gonna weld in a piece of sheet metal, then re-cut the circle for the headlight wiring. |
When i pulled the 305 i started rebuilding the 700. When i took it apart everything was alright except both the accumulator springs were broken. I bought a rebuild kit with alto clutches and new steels. Swapped in a corvette servo with a trans-go jr. shift kit, and .500 boost valve. Here are some pics from pull to finish. I'm bringing it to school tomorrow to throw on their trans dyno.
http://img17.imageshack.us/img17/462/082111123701.jpg http://img854.imageshack.us/img854/2199/sam0090x.jpg http://img847.imageshack.us/img847/3296/sam0104t.jpg http://img713.imageshack.us/img713/585/sam0116n.jpg http://img824.imageshack.us/img824/7271/sam0117i.jpg http://img687.imageshack.us/img687/2...2711213500.jpg Fresh coat of Chevy orange. http://img263.imageshack.us/img263/3...2911115900.jpg http://img21.imageshack.us/img21/4582/082911115901.jpg http://img23.imageshack.us/img23/7112/082811183700.jpg All finished. http://img851.imageshack.us/img851/3...1111184301.jpg |
Put the trans on the dyno and it worked perfectly. Now i need to rent a truck so i can pick up the 350 that i am going to start building. In the meantime prepping the engine bay for paint.
Originally Posted by mgg4591
(Post 572874)
it's a project of passion and you're going about it the right way. |
Originally Posted by torque_is_good
(Post 572944)
http://img217.imageshack.us/img217/8...2211151300.jpg http://img339.imageshack.us/img339/8...2211151400.jpg http://img838.imageshack.us/img838/2...2211151202.jpg http://img220.imageshack.us/img220/3...2211151301.jpg http://img24.imageshack.us/img24/9936/092211182301.jpg http://img17.imageshack.us/img17/1483/092211182400.jpg http://img607.imageshack.us/img607/9...2211182501.jpg |
you're spraying it outside???
When i did mine, I used the garage and still got freakin bugs in the paint. What are you using? I tried an HVLP turbine for the first time and was surprised at how well it worked. The guns cost more and you need to thin the material more than with a compressor. |
(Post 573167)
