305 TBI swap to 350 carb
Old Jan 26, 2018 | 12:31 AM
quentin3391's Avatar
Default 305 TBI swap to 350 carb
have a 350 bored.60 ,elderbrok carb and intake ,headers,holly return style the,oil and water gauges,hei vac distributor,tci look up kit but still have too much fuel pressure on gauge what's wrong
Old Jan 26, 2018 | 06:41 AM
Are you using the factory 12 PSI electrical fuel pump?
Old Jan 26, 2018 | 09:20 AM
yes I am
Old Jan 26, 2018 | 10:04 AM
Everett#2390's Avatar
Add Holley regulator before carb and set for 5-6 PSIG and use return line.
Old Jan 26, 2018 | 11:42 AM
Default Fuel pressure regulator
i did install the Holley HP 803 but still high
Old Jan 26, 2018 | 04:18 PM
803 is adjustable from 4 to 9 PSIG
View installation here, Fig 2A & 2B
http://www.jegs.com/InstallationInst...0-12-803BP.pdf
802 has one inlet and two outlets, one outlet could be return.
quentin3391
Oct 26, 2017 10:15 AM
Joeycotton
82-92 V8 Tech
Mar 29, 2012 02:27 PM
firebird56265
82-92 V8 Tech
Jun 7, 2011 11:23 PM
caldwell91camaro
82-92 V8 Tech
Jun 26, 2008 09:30 PM
BlitzKrieg
82-92 V8 Tech
Mar 20, 2008 01:46 AM
