1986 IROCZ Value assistance
Old Mar 15, 2018 | 02:24 PM
34ford454's Avatar
Default 1986 IROCZ Value assistance
Hello all. I have a strange request that lends itself to my third gen Camaro value knowledge. I have build a totally custom Z and will be completing it in the spring with a fresh red paint job. This is a twin turbo 350 and is wicked fast. I have no knowledge of the market value of the car as its specs are listed below. I need an educated evaluation as close as possible regarding the cars value when completed. It has approximately 40 miles on the new engine. I know this is a weird request but due to my lack of Camaros sold today I need some help on this.
Thanks in advance and below is the car specs and a picture of the engine bay. Multiple photos are also available upon request.
Gen 1 350 with all newstandard components; standard crank, rods, standard pistons, rings, bearings, camand crank
New HOWARD'S SBC ChevyRetro-Fit Hyd. Roller 270/278 495"/500" 108° Cam Camshaft Kit
New Proform 66906C StampedRoller-Tip Rocker Arm 1.5 Ratio 3/8 in. Stud
--Clamshell
2 New intercoolers
New Mighty Demon blowthrough 750
New Eldebrock polishedintake manifold
New Elgin 1.94"Intake & 1.5" Exhaust Valve Set
New Felpro gaskets
New Electric water pump
New Melling high volumeoil pump with pick up
New Acel HEI Dist.
New MSD 6al2 programmableign
New Cloyes timing gearcover for roller cam
Ported and polished heads
New plug wires
New Holley 140 GPHelectric fuel pump
New Holley 4-9 PSIadjustable fuel pump reg with return port, boost --referenced
New Twin t-3/4 turbos
New MSD Tach converter box
Flowmaster Muffler, BigBlock II 70 Series, 2 1/2 in. Inlet/2 1/2 in. Outlet, --Steel, Aluminized
Corvette Fiberglass taillight panel and quad exhaust tips from C4
Custom dash and all newgauges including boost
New door and window rubbermolding
Custom gear shifter for700R4 transmission
Electronic wirelessexhausts cut-outs on both sides
New oversize Tires
4 wheel disc brakes
New Front brakes
Posi-traction 3:08 rear
New Champion 3 rowaluminum radiator
Driver and passenger seat recovered
34ford454
Mar 12, 2018 04:13 PM
34ford454
Mar 12, 2018 04:12 PM
Chooseup
Feb 28, 2007 12:23 AM
irocz1985
Apr 20, 2006 08:03 PM
Halinst
Jan 22, 2006 09:35 PM
