Wiring Issues
Old Apr 25, 2008 | 09:24 PM
CCarRocks's Avatar
Default Wiring Issues
Okay all, I recently purchased a 1986 IROC thatisvery nice body & drivetrain wise. However it has some wiring issues.
Its many things some are I can turn off the key & it will run for about 2 to 3 seconds before it shuts off. Its a carbed engine not injected.
Sometimes when I turn on the right blinker the oil gage,tach & other gages move in sync with the signal.
The horn isn't working but I found a wire not connected behind the horn button, hopefully that's all that is.
Is there a place to buyharnesses soyou can change out old ones?
All other advise is really welcomed.
Thanks all,
CCar
Old Apr 25, 2008 | 09:29 PM
rockin85's Avatar
Default RE: Wiring Issues
check for a bad ground. they can mess up a lot of things. my lights were always on no matter what until i cleaned up all the grounds.
Old Apr 25, 2008 | 10:03 PM
CCarRocks's Avatar
That's the second time I've been given that advise. I'll start on it tomorrow withan ohm/volt meter.
Does anyone have more hints?
I'm pretty sure whenthe engine was installed they probably removed a TBI or TPI because the wiring looks all junked up.
I'll try & post some photos of the car.
Old Apr 25, 2008 | 10:34 PM
MadMikeZ28's Avatar
ORIGINAL: rockin85
Now that makes 3 times. That will do the funny things to your gauges. But with the car still running. Is it running like as if the key was still on or chugging (dieseling/run on)?
If its running as if the key was still on then I would suspect the ignition switch. It should be killing power and may not be. Maybe sticking and it takes 2-3 seconds for it to slide into the off position.
If its dieseling then check the idle and timing. Idle too high or timng off?
Old Apr 26, 2008 | 12:42 PM
CCarRocks's Avatar
Nope its not the dieseling thing, it just runs like the key is still on. I'llcheck & see ifits sticking or just needs to be replaced. I also wonder if by some chance there is bleed over voltagefrom the alternator. Its a mess under the hood IMHO. Photos when I can get them uploaded.
Xios
Feb 20, 2015 03:49 AM
Mikeroc283
Apr 14, 2014 07:39 AM
lbx45
Sep 22, 2013 01:15 PM
Intrepid781
Sep 25, 2008 02:41 AM
sloridem
Dec 23, 2007 03:02 PM
