Where is the tranny modulator valve 86 IROC
Old Apr 3, 2012 | 12:11 AM
ryanncully's Avatar
Default Where is the tranny modulator valve 86 IROC
I have an 86 IrocZ with a 350 bored 40 over and i just put a new Edelbrock 650 on it and im looking for the the tranny modulator to hook up the vacuum lineso my car shifts correctly.
Thanks
FYI I just got into Chevy SB from tuning STI's so im having to learn somethings
Old Apr 3, 2012 | 12:36 AM
Your car came with a 700R4. It doesn't have a vacuum modulator, but it does have a TV cable that needs to be set correctly. However, if someone swapped in a TH350 trans, that's a different story.
Here's how to tell what trans you have: http://www.layitlow.com/forums/22-ma...formation.html
Here's how to set the TV cable: http://www.maddogtransmissions.com/v.../tv_cables.pdf
And if you don't have this linkage arm on your carb, you need to get one to help prevent the trans from toasting: http://static.summitracing.com/globa...tci-376710.pdf
Old Apr 3, 2012 | 01:32 PM
ryanncully's Avatar
thanks man appreciate the knowledge
fronzizzle
Jul 26, 2011 11:33 AM
cschues80
Mar 7, 2010 11:25 AM
thebandit110
Apr 7, 2008 11:21 PM
LetchcoreCJ7
Jul 4, 2005 08:10 PM
