Where to find fuel tank sending unit?
Old Jun 21, 2009 | 06:36 PM
Jr. Mechanic's Avatar
August 2009 ROTM
Default Where to find fuel tank sending unit?
It's really a pain not having a fuel gauge, and I know my sending unit is bad. I went to advance hoping to get a new sending unit and pickup, only to find that they've discontinued it since the last time I checked. Advance, Autozone, and Rock Auto can't get it. Couldn't find either one on ebay either.
Also, my car came with CFI, and was later converted to carb. I'll be fine just getting a sending unit and pickup from a carbureted model of the same year, correct?
Old Jun 21, 2009 | 09:01 PM
u will need to make sure the mounting on the tanks is the same for both. i would not think gm would make two different tanks for the same model and yr. but ive seen some strange things.
Old Jun 22, 2009 | 10:11 AM
350rs's Avatar
March 2008 ROTM
Couldnt you just run to the junkyard with old part in hand and check out a few? I would think that the drop in would be identical throughout but maybe the lock ring be different in some way. Might be a way around it. Get one for FI and run a good regulator with a return so you dont burn it up.
Shoot, if you cant find it. Pull that lame ol 350 of yours out and put in a LS1. Totally worth the unrelated problems right? HA HA!! Even though that wouldnt fix what your after..
Old Jun 22, 2009 | 02:34 PM
August 2009 ROTM
I would prefer to get new, the sending unit isn't something I want to replace more than once (damn GM engineers and their gas tank placement )
I have a V6 parts car that I'm sure I could make the sending unit work, but like I said I would like new.
The LS1 is sounding pretty good right now. I've gotta replace the valve seals on my new engine because I cheaped out while building it and now I have smoke
Old Jun 23, 2009 | 01:40 AM
350rs's Avatar
March 2008 ROTM
well there ya go. might as well pull that bastard out and build up a LQ9.. lol
Old Jun 28, 2009 | 06:46 PM
August 2009 ROTM
Nah. She's gettin a new set of aluminum heads. I think im gonna go with the Patriot Performance 190cc 2.02 heads. It's plenty quick for me right now, I've got a bad hesitation though off idle I can't figure out.
First is axles for the Jheep though. My Dana 35 blew out and i've got a Dana 44 with a matching front axle lined up for $300 with all new moog steering parts.
Oh yeah, NOBODY can get that part. It's like someone bought them all and hid them. I checked availability less than a year ago and advance had the sender in stock for $15 bucks. Looks like I've got a project on my hands now...
Old Jun 29, 2009 | 10:01 PM
91ralllysport's Avatar
im trying to find a sending unit also with no luck i have a horrible fobia of running out of gas and my car always reads past full unless i get under a quarter of a tank.
Old Aug 29, 2009 | 08:47 AM
cricket5150's Avatar
Default Sending Unit
I seem to be having the same problem. I have a 91' RS, took out the ol' piece of garbage 305, and bought me a new 383/452 HP turn key engine. Now the problem is my furl lines run on the drivers side my pump is on the passenger side. I want to run new stainless lines but cant find a sending unit. WTF? So maybe someone here has a clue? And I dont want to keep the electric pump anymore, so a regulator isn't the answer for me...
Old Aug 29, 2009 | 11:47 AM
August 2009 ROTM
I ended up buying the complete fuel injection assembly for a 1988. $180 without the fuel pump, then I put a piece of fuel hose in place of where the fuel pump normally goes and removed the wires for the fuel pump. Being that I have an 83, I also had to reuse the plug from my older sending unit, and extend the wires to reach the connector.
Old Sep 1, 2009 | 12:25 PM
COOLVETTE01's Avatar
This may be a dumb question considering the " 1983 camaro z28. No, it's not stock." at the bottom of your post but what model is your camaro and what engine do you have?
