where can i find the egr on an 86 tpi?
Old Mar 31, 2007 | 01:23 AM
microkid's Avatar
March 2011 ROTM
Technical User
Default where can i find the egr on an 86 tpi?
i was reading an old article from the late 80's with a 305 tpi firebird.(http://www.thirdgen.org/slptpibuild-hpp-feb89 ) they were able to pick up a full second with just some minor things, such as unblocked the hood scoop, blocked egr, 12* timing, and a 160* thermostat. i still havent figured out how to change the timing, but i prolly wont fool with that. what i would like to know is where the egr is on the 86 tpi. it serves nothing more than to reduce emissions, kill hp, and help keep the valves cooler. a picture would be great
Old Mar 31, 2007 | 03:27 AM
MadMikeZ28's Avatar
Default RE: where can i find the egr on an 86 tpi?
I do believe its under the plenum.
Old Apr 11, 2007 | 11:57 PM
microkid's Avatar
March 2011 ROTM
Technical User
would it be the smaller tubes between the pairs of tubes, kind of inside? when i took my plenum off, i noticed them, and they were full of a carbon and shizzle. is there any way to block them off for more performance?
Old Apr 12, 2007 | 12:01 AM
MadMikeZ28's Avatar
I thought it just looked like a regular egr valve. I may be wrong as I usualy am. Next to the 1&3 runners????
Old Apr 12, 2007 | 12:05 AM
coprunr's Avatar
the egr on those is a standard EGR valev, can't get it off without ranking the runnder and plenum off.....it's a big circle under the intake almost in the center if the intake
Old Apr 12, 2007 | 12:26 AM
MadMikeZ28's Avatar
ORIGINAL: coprunr
Thats pretty much exactly what I said.......so I'm not tripping!
Old Apr 12, 2007 | 06:43 PM
microkid's Avatar
March 2011 ROTM
Technical User
ill check it out in my book if i can remember. i had it all off recently to replace the fuel regulator, and the only big circle that i remember is the pressure regulator.
does anyone know what those two smaller tubes would be?
Old Apr 13, 2007 | 12:49 AM
MadMikeZ28's Avatar
Take a pic of them and post it. The only extra small tube I can think of was an extra injector for cold starts on early TPI. But I thought that was one extra small runner
Look in your Camaro performance handbook. Pg.60. There is an Accel manifold at the top and you can see where the egr bolts to the near center of the manifold.
bezerker
Feb 2, 2009 12:23 PM
350rs
Dec 10, 2008 09:07 AM
97rsturbocamaro
Jan 12, 2008 10:11 PM
lgeiger13
Oct 2, 2007 08:56 AM
Spartan66
Aug 21, 2007 10:47 AM
