What pressure setting?
What pressure should we set our fuel at when we get our 26# injectors in? We currently have it at 50# with the crappy 24# injectors that are getting replaced. Please let me know because we want to do all of this at once. I will also post this in the tech section, but I didn't know if any third-gen guys knew a good setting.
Go with the factory setting of 40 to 45 PSI. The computer will adjust the injector pulse duration to get the proper fuel mixture. If you increase the pressure, the computer, after a number of starts, will reduce the pulse width so that the amount of fuel delivered remains the same. If you want to change the A/F ratio, the computer tune will have to be changed.
