Fuel pressure setting
Old Apr 11, 2006 | 01:32 PM
HaloNick's Avatar
Default Fuel pressure setting
What pressure should we set our fuel at when we get our 26# injectors in? We currently have it at 50# with the crappy 24# injectors that are getting replaced. Please let me know because we want to do all of this at once. Oh and it is in a 5.9L TPI setup in a 92 Camaro.
Old Apr 16, 2006 | 10:08 PM
Default RE: Fuel pressure setting
Set to the factory spec 41 to 45 PSI. The compoter will correct the pulse width of the injector to get to the programed fuel mixture. Changing fuel pressure will not change the A/F ratio. You need to get the PCM tuned if you want a different A/F ratio. Actually, the A/F ratio will change temporarily with changes in fuel pressure, but the computer will eventually bring it back to normal.
Kendagenius
Feb 5, 2017 12:23 PM
royco95
Aug 2, 2015 10:25 AM
BoricuaHec01
LS Series Tech
Mar 17, 2011 05:56 PM
HaloNick
Apr 13, 2006 02:21 AM
