what have i got myself into
Old May 15, 2011 | 12:04 AM
ohio4332's Avatar
Default what have i got myself into
Just bought my first 1988 iroc. switched over from a dodge charger,what kinda power is this beast pushin out so far it has a new 350 sbc with 650 carb,hooker headers msd coil, flow master duals, 2l radiator, and some other slight mods
Old May 15, 2011 | 12:19 AM
Somewhere between 175 and 450 h.p. Is your engine the original one? Has it been rebuilt, and if so with what components? Without knowing just what you have, there's no real answer to your question. If you assume your new engine is rated as the original 230 hp engine was (to use as a baseline), you might be looking at somewhere in the 260-270's. But still, any answer you get is just going to be a wild guess.
Old May 15, 2011 | 07:47 AM
ohio4332's Avatar
Yea thats what i was thinking, i talked to the guy he said around 350hp, i guess ill have to use the butt dyno when the tune up and timing work are done
Old May 16, 2011 | 08:27 AM
microkid's Avatar
March 2011 ROTM
Technical User
also depends on gearing if thats been altered for the butt dyno
