what gears to get?
Old Aug 12, 2005 | 02:35 AM
92camaro305's Avatar
Default what gears to get?
I want to put new gears in the rearend to get alot more out of it but i use it as a daily driver too. Its got overdrive...........i was thinking 373's or should i go higher?
Old Aug 12, 2005 | 12:56 PM
Default RE: what gears to get?
Being that you have overdrive, you can probably go all the way to 4:11. The car will be a liitle buzzy on the highway, but that is the price u got to pay. Make sure you get a limited slip diff to go with the gears otherwise all the extra torque will go up in smoke.
Old Aug 12, 2005 | 06:16 PM
aaronsirocz's Avatar
yes go with the 411's thats what i have on my iroc, and it made a big difference on acceleration.
Old Aug 12, 2005 | 08:24 PM
Thanks i think i will go with the 4 11's but how much does a limited slip cost and where is a good place to find one?
Old Aug 13, 2005 | 02:15 AM
I think it will be tough to find either one at a salvage yard. As most cars don't come with 4.11s and I really don't trust a used limited slip. U can go online to a performance parts store such as Jegs http://www.jegs.com/ or Summit http://www.summitracing.com/ They have just about all you need.
Also, setting up rear end gears is a critical process and requires specialized tools. Find a gooe rear end shop to do the work.
Old Sep 12, 2005 | 12:55 AM
thanks for the help guys.......i have changed rear end gears many times in my race car, im kinda low on money right now and i have 342's laying around off of my race car so im gunna put them in for now untill the winter when i do my 350 motor swap and stuff
thanks
sepadowd
Aug 4, 2011 07:59 PM
91camaro350
82-92 V8 Tech
Aug 5, 2010 10:28 AM
gfrench
Jun 19, 2010 10:16 PM
1bad96Z28
Jun 9, 2007 09:12 AM
