what to do?!!!!!!!!
i have a 86 camaro an it had the 2.8 v6 in it i got a 350 for it an dont know if the trans will fit from the v6 reason i need it to is its 5 speed an its been redone by b&m so will the trans bolt up or not an if not can i get a 5 speed trans from a rs or z28
you're gonna need at least a new bellhousing. the 2.8 is a 60* v6 and has a completely different bolt pattern than the any SBC (90* v8). personally, i'd say scrap the T5 and look for a T56 (out of an LT1 4th gen preferably). i've heard of T5's failing behind a stock TPI 305. that 350 will practically eat it for lunch.
If it was indeed rebuilt by B&M, the odds are it's already beefed up. You will need a bell housing from a V8, and IIRC, you will need a clutch that fits the V6 T5 specifically, because of it's 10 spline input shaft vs the 28 spline that the V8's use.
They do make a coversion clutch for it if it is the 10 spline since the V6 clutch is 9" or 9 1/2" that is weak vs the 10 or 10 1/2' clutch that was installed in the V8 you will want to look for one.
