Washing the engine??
Old Apr 12, 2009 | 01:35 PM
adirtypoostick's Avatar
From: IN, or hell whichever, wait, its too cold to be hell
Default Washing the engine??
I have a dual plane intake with a gap under the carb, I was wondering if it is ok to hose that down really good at the car wash. Also I a trying to track an oil leak that I think that I have fixed, Is it ok to hose the entire engine as long as I cover the carb and distributor?
Old Apr 12, 2009 | 07:39 PM
ive taped plastic bags (heavier like bread bag) on the carb/tb (taking off the air cleaner) and on the distribitor and done it with a small presure sprayer no problem. thats on my truck with a tb injection and normal distr. bring a rag just in case you need to dry the wires to get it to fire. did the z right before replacing the opti. to clean it up & to make sure i got all the oil leaks after done. with the type of air cleaner on it i just left it on. did motor and trany as much as i could get to up on j stands. worked good. much cleaner work invironment.
Old Apr 12, 2009 | 08:37 PM
Yes you can, but be sure to cover up the alternator too.
rj44130
May 12, 2012 01:39 AM
brainwavewow
Jul 17, 2011 12:53 PM
auto
Oct 15, 2009 06:54 AM
CamaroKid16
Jun 25, 2008 07:43 AM
Attila
Nov 9, 2007 09:34 AM
