Vortech Supercharger
Old Jun 27, 2005 | 08:26 PM
Boost's Avatar
Default Vortech Supercharger
Has anyone done a Vortech SB Supercharger kit to a Stock Carbed 305??? I was lookin into it and wanted to know if i can do it without changing the fuel system...
Old Jun 28, 2005 | 03:46 PM
Patrick's Avatar
Administrator
Default RE: Vortech Supercharger
didnt vortech have any input?
Old Jul 4, 2005 | 09:42 PM
Boost's Avatar
None that i know of... Ill blast them an Email to see... Im gonna change the carb and intake anyway...
Old Jan 19, 2007 | 05:33 PM
kickerdx's Avatar
i am also looking for similar info
Old Jan 19, 2007 | 08:57 PM
92camaroRS's Avatar
well for one i definatley wouldnt supercharge a 305
Old Jan 19, 2007 | 09:06 PM
Andross's Avatar
Yea, I'd get a 350 first at least. More potential.. Ya know? But hey if a 305 works, you do what you can.
Old Jan 19, 2007 | 09:09 PM
The kit will definetely have to have some enhancments to the fuel system in order to adjust fuel pressure to the carb to prevent flooding and starving as the blower pressure increasesor decreases. Having dealt with blow through system, I find them to be a real pain in the ****. Personally, if I had to use carbs I would go with a roots or screw type blower to avoid the fuel pressure issues, and just deal with greter fuel delivery to the carb.
Old Jan 19, 2007 | 09:28 PM
Raven91Z28's Avatar
If you supercharged a 305 and left the stock fuel system on there, you would have some major air/fuel ratio problems. If you're adding way more air, you need to add more fuel. I also agree that with carbs, go with a roots style blower....
Old Jan 19, 2007 | 10:30 PM
americanpower454's Avatar
or you can look into a procharger they make kits for carbed applications and they are intercooled which is better for your engine. Plus they compensate the fuel pressure by closeing off the return line in relation to the amount of boost.
NomadicZ28
Nov 7, 2007 09:58 AM
LTHL PSI
Aug 2, 2006 08:37 PM
superROB23
Jul 14, 2006 04:31 AM
JoeBlowRacing
Aug 9, 2005 06:07 AM
