vats system on 89 chevy camaro
Old 08-17-2006, 05:09 PM
siw234's Avatar
Default vats system on 89 chevy camaro
like anyone else sometime in your life with your camaro you have a problem with the car not wanting to start because a problem with the vats system my problem was first the sterring column went bad.I could not find a 89 column any column will work all you need to do is use your wireing fish it through the column and your business.
Secound problem was when I would turn the key to start it would not turn the solution was to replace it with a $80 unit and new key.I did not want to spend that most so I find out how to replace the Vats System. Clip the 2 wires going to the unit go to Radio Shack and have them to rum ohm test to see how much curcuit is going though the system than fo $1.00 purchase ohm resistor attach it to the 2 wires replace the key/switch unit for $12.00 at advance auto parts and your are in business
Old 08-17-2006, 11:08 PM
Hawk's Avatar
January 2007 ROTM
Default RE: vats system on 89 chevy camaro
Since your post stated : vats system on 89 chevy camaro
I moved it from the " NEW MEMBERS " section in the forums and placed it here due to the fact of the subject matter.
Thx for the info.
boboridesthefa
07-26-2014 02:50 PM
karma187357
10-28-2011 06:10 PM
mtv101
03-14-2010 09:01 AM
89CAMRSID
10-24-2008 02:07 AM
355CAMARORS
02-19-2007 11:39 PM
Quick Reply: vats system on 89 chevy camaro
