Vats
Old Jan 21, 2007 | 02:48 AM
griff305's Avatar
Default Vats
does any1 have the schematics for the vats system. Mine is a mess and i want to see what the hell is gooing on
Old Jan 21, 2007 | 02:30 PM
Default RE: Vats
You didn' say what car you are working with.
However, this link shows the diagram for a 94 Camaro, http://shbox.com/1/pass_key.jpg
Most GM cars using VATS follow the same layout. Keep in mind that the car will not work without the VATS module unless the PCM is reprogrammed or extensive rewiring performed. The key, and the key contacts can be bypassed by strapping a proper value resitor to the 2 wires going to the VATS module, but the module has to be kept active. When the VATS module sees the proper resistance from the key, it sends a coded digital signal to the PCM. When the PCM sees the signal, itenables the fuel injectorsand power to the starter relay.
Old Jan 23, 2007 | 01:52 AM
griff305's Avatar
Default RE: Vats
thanks alot it is a 92 and somebody really messed with the vats i need to trace all the wires do u have any links for the rest of the anti theft
Old Jan 23, 2007 | 08:02 AM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Old Jan 23, 2007 | 03:06 PM
griff305's Avatar
Default RE: Vats
the decoder module isnt plugged in the green loop in it is cut. Previous owner ran a switch from the grey wire. It fired over when i bought it, it sat for a while and then just wouldnt fire. What is the clear component with the red and green led's in it?
Old Jan 28, 2007 | 01:39 AM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
Default RE: Vats
not sure what you mean. can you take a pic maybe?
sgtdupree
Sep 20, 2012 02:25 AM
mccoyj91
Nov 3, 2010 06:13 PM
thetal1
Aug 19, 2010 01:50 PM
JES89rs
Jul 5, 2009 02:42 PM
Z28Reggie
May 14, 2009 04:26 PM
