vacum lines? help please!
RE: vacum lines? help please!
OK then it is TBI. Fluffy corrected me and said you had TPI. HE LIED!
The diagram you attached looks correct and if you get stuck I also have a TBI (the one that looks like the carb) and can help.
Good luck
Good luck
ORIGINAL: MadMikeZ28
Good luck
Good luck
ORIGINAL: motortec
oh ya i used the 305 intake mani an throtle body (tpi)
TPI is Tuned Port Injection, and is a typical example of what we mostly just call fuel injected.
TBI is Throttle Body Injection, and is somewhere along the lines of Carb meets Fuelie, using injectors mounted over the throttle body, much like jets on a carb would be.
The lesson wasn't inteded for you =p
I was just pointing out that he DID in fact, say he had a TPI at some point. I know full well that you know at least as much as I do about cars, probably more, and absolutely know more vehicle specific info for Camaros I'd never challenge your authority. Motortec, on the other hand, is still learning, and seemed to need a lesson.
