vacum lines? help please!
Old Nov 5, 2006 | 09:33 PM
motor tec's Avatar
Default RE: vacum lines? help please!
does this look right to anyone
Old Nov 6, 2006 | 03:01 AM
MadMikeZ28's Avatar
That pic is for a TBI. Do you have that or TPI?
Old Nov 6, 2006 | 03:10 AM
MadMikeZ28's Avatar
A thought just came to mind....Do you have the underhood sticker? It would look simalur to your diagram.
Old Nov 6, 2006 | 07:04 PM
motor tec's Avatar
it's the one that looks like a carb an no theres no sticker....
Old Nov 6, 2006 | 10:55 PM
MadMikeZ28's Avatar
OK then it is TBI. Fluffy corrected me and said you had TPI. HE LIED!
The diagram you attached looks correct and if you get stuck I also have a TBI (the one that looks like the carb) and can help.
Good luck
Old Nov 7, 2006 | 01:48 PM
FlufyTiger's Avatar
ORIGINAL: MadMikeZ28
Good luck
ORIGINAL: motortec
oh ya i used the 305 intake mani an throtle body (tpi)
Seems to be a bit of confusion going on here.
TPI is Tuned Port Injection, and is a typical example of what we mostly just call fuel injected.
TBI is Throttle Body Injection, and is somewhere along the lines of Carb meets Fuelie, using injectors mounted over the throttle body, much like jets on a carb would be.
Old Nov 7, 2006 | 04:31 PM
MadMikeZ28's Avatar
Fluffy
I dont need a leason. My first assumtion was correct until you screwed it all up.
Old Nov 7, 2006 | 04:51 PM
FlufyTiger's Avatar
The lesson wasn't inteded for you =p
I was just pointing out that he DID in fact, say he had a TPI at some point. I know full well that you know at least as much as I do about cars, probably more, and absolutely know more vehicle specific info for Camaros I'd never challenge your authority. Motortec, on the other hand, is still learning, and seemed to need a lesson.
Old Nov 7, 2006 | 05:18 PM
T10wheels's Avatar
The guy did say he was using tpi in an early post.
Old Nov 7, 2006 | 05:59 PM
  #20
uncle bill's Avatar
Geez......................
