Tranny Fluid DEXRON 2 vs DEXRON 3
Old Apr 13, 2007 | 12:17 AM
Goodfella's Avatar
Default Tranny Fluid DEXRON 2 vs DEXRON 3
Real Quick. I was fl;ippin through my chilton's and decided i wanted to change my tranny fluid. I hava 92 z28 with the BW T-5 manual tranny. it called forDEXRON II ATF ( for the manual tranny!!!!!). So i went ahead and bought 2 gallons of DEXRON III (3), knowing that dex 3 is backwards compatible.Now I dont know if this will be okay to use in my car, but im pretty sure, i dont want to screw anything up, by puttin different fluid in. Can anyone verify this for me? Also what fluiddo you guys put in yourmanual cars? Thanks
Old Apr 14, 2007 | 12:23 PM
FlufyTiger's Avatar
Default RE: Tranny Fluid DEXRON 2 vs DEXRON 3
That is what GM used in there, but I have heard of people using a heavier single weight motor oil, or even 75w90 gear oil (ATF is right around a 10 weight). None of those should have any trouble in that transmision, though, the heavier the weight, the more parasitic draw from the tranny (this likely won't be noticable unless you're in a higher racing class, which I kinda doubt)
BasicConcepts
Mar 15, 2010 08:04 PM
KingJames499
Mar 30, 2007 12:26 AM
Saint_Ali
Aug 10, 2006 10:36 PM
NomadicZ28
Jul 3, 2006 06:51 PM
