Trailer Hitch
Old Oct 14, 2010 | 10:45 PM
RSSSCamaro's Avatar
Default Hitch
I just bought a hitch off of a 1984 Pontiac Trans Am, I only had to trim the bottom lip off of the carbon fiber reinforcement bumper absorber for clearance, then it bolted right up. So third and fourth generation cars are the same as far as hitches go. I didnt want to do this, but as of September 1 I am single, and she took the Suburban... You have to use what you have right? Best of all the hitch is like new, and it costed 30.00 off of Craigslist.
Old Oct 15, 2010 | 02:05 PM
djs383's Avatar
Originally Posted by Trashy
hello saint ebony,
finially an intelligent question. I am pulling a super light trailer with a dirtbike. Yes my v6 can pull it so dont think I dont what I am talking about it.. I just wanted to know if another car had a similar mount. But I can probably pick on off any of the others and cut it down to fit
You'll be ok, but keep in mind that car will not last very long doing that. I'm not sure what you are riding, but a 250F/450F weighs 225-245 thats the mx version, an off road version weighs even more, plus with gear, gas, tools, water etc it doesn't take long to get to 500 lbs at all. Not the best on the motor or trans.
Old Oct 17, 2010 | 07:47 PM
rj_moore's Avatar
Hi, I have a 1987 Camaro IROC Z28 with a single exhaust at the rear of the car and two exhaust pipes out the back. Do those Reese hitch is 77006 that brand says from 1982 to 2002 tongue weight is 200 LBS trailer wieght is 2000 LBS, Curt Manufacturing is part # 11117, fit that exhaust set up. Its stock for my 305 5.0L TPI 5 speed. All I have found online, including the Curt say single exhaust pipe or no hitch.
Please advise. Richard.
Old Oct 17, 2010 | 08:03 PM
rj_moore's Avatar
Question
Originally Posted by RSSSCamaro
As far as I can tell, they fit from 1982 to 2002, the part numbers are the same from what I see online.
The part number for a Reese hitch is 77006 that brand says from 1982 to 2002 tongue weight is 200 LBS trailer wieght is 2000 LBS, Curt Manufacturing is part # 11117 the Curt hitch is rated for 100 LBS Tongue weight, or 1000 towing weight.
I have a 1987 IROC Z28 and want to install a hitch for bikes, camping, etc., and I have been unable to fine one which fits a single muffler, and two tail pipes, including the Curt 1117.
Old Oct 29, 2010 | 09:13 PM
84Bluechevyz28's Avatar
you can find trailer hitches out there in the junk yards, just have to search, or try craigslist/ebay,
I have one on my camaro Z28 with a 383, I use it to pull a jetski
Old Oct 30, 2010 | 01:03 PM
rj_moore's Avatar
Question Trailer Hitched Camaros
I am looking to 'tow' a cargo basket, a bike rack and a surfboard rack, but I have a single muffler with dual exhaust tips, and can't find a hitch which will accommodate that muffler setup.
How did you get around that problem? did you find a trailer hitch which accommodates a dual exhaust tip set up?
Richard.
Old Nov 5, 2010 | 12:28 AM
Caveman305's Avatar
my buddy bought an LG4 bird that had one on it when he bought it, he had single muffler and dual pipes, but i think the previous owner had it made and put on at a hitch shop
the PO said he used it to pull a Tire Trailer to and from the track(and yes it was fully stock when my buddy got it), and the only time it pulled serious weight was when he moved from VA to MD and rented a Uhaul trailer to bring his stuff with him
anyways, junk yards are chock full of hitches, go pull a few From similar cars, one of them will either work, or need very little modification to work
Old Nov 19, 2010 | 05:32 AM
RSSSCamaro's Avatar
Default hitch
My car has dual exhaust, and my hitch bolted up fine. The exhaust is in its stock location as well. When they say dual exhaust I think they are meaning the centered dual exhaust, on the 1998 to 2002 SLP cars with that package.
Old Nov 20, 2010 | 02:38 AM
rj_moore's Avatar
Default Dual Exhaust Trailer Hitch 1987 and 1985 305 5.0L
The online trailer hitch guys tell me there are not any for my two Camaros because of the years, 3rd Gen.
Richard.
Old Dec 1, 2010 | 02:14 PM
  #20
carguy68ssrs's Avatar
Let's not worry about the weight since he's not going to have it hooked up all the time. The car will be fine if he finds the right hitch. If you give 3 of your buddies a ride how much do you think they weight?
hitchedcamaro
Jun 17, 2012 10:37 AM
rantheman
Nov 23, 2009 01:01 PM
Goodfella
Jul 22, 2006 02:48 AM
JoeDubs86
Mar 2, 2006 10:18 PM
