TPI swap Hp gain
#22
RE: TPI swap Hp gain
it will clear a stock hood , even a flat sport coupe hood. one thing i didn't think about was , your engine being a 92 means the center bolts on the intake are at a different angle than the 86 down heads. i'm not 100% sure the stealth ram has provisions for the different angle but i belive it does (have elongated holes in the center so you can use it one either style head) , they also have one designed for the Vortec heads now. Vortec heads , a LT1 camshaft and the Stealth Ram sitting on top would be killer!
#23
the stealth ram is a good bit of money too. Im sure the stealth ram will help a lot, but your gona be looking at a LOT of money in the end. You might as well save up and buy some better flowing heads while your in there. heads+cam+tpi+stealth ram = lots of power. BTW, you also have to buy holley fuel rails to use the stealth ram, the stock ones wont work. they are for sale along with the manifold.
carburated, conversion, converting, efi, gain, gains, horsepower, hp, lt1, plenum, port, siamese, swap, swapping, tpi, tuned
