is there a difference?
Old Mar 28, 2007 | 08:27 PM
86irocz's Avatar
Default is there a difference?
My transmission is going out so im going to swap both the engine and transmission. I currently have a 305 tpi witha 700r4. Im not changing the tranny so i dont need help there. Im swapping to an 88 350 tpi. I have everything for it including the ecm, prom, and everything else. But i already have the tpi wirng harness in my car so i was wondering if i could just plug the ecm and the prom into my wiring harness and everything hook up on the 350. Would that happen? Also would a set of 305 H.O. heads do any good on a 350? Thanks for any help or opinions.
Old Mar 28, 2007 | 09:40 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: is there a difference?
im pretty sure the wiring harness should be pretty close. the only real difference is the ecm and injectors
Old Mar 28, 2007 | 10:29 PM
MadMikeZ28's Avatar
You may also need a knock sensor and/or an esc. The esc for sure though. The 305 heads will bump your compression but you may want to put some bigger valves in them
Old Mar 29, 2007 | 12:26 AM
coprunr's Avatar
like madmike said, the 305 heads will bump up your compression, but they stop flowing @ about 4200rpm. the knock senor is different , but i suggest putting a knock sensor for a LT4 Corvette in it instead of a stock one. the LT4 knock sensor will allow the engine to run a bit more timing (only a degree or two) but somettimes it's enough to make a difference in the way the car runs .the ESC is the same , same part # for 5.0 and 5.7. so as long as you get the prom chip , injectors , and knock sensor for a 5.7...you should be ready yank and drop.
Old Mar 29, 2007 | 01:39 AM
MadMikeZ28's Avatar
ORIGINAL: coprunr
I would check that again. The Electronic Spark Control (the part the knock sensor sends it signal too) is not the same part numbers for a 305 and 350.
Old Apr 2, 2007 | 02:21 PM
86irocz's Avatar
I'm pretty knew to this tpi stuff. Im an old chevy man. Im getting the motor out of a donor car that has been wrecked so everything is there. Also do i need to swap out any gauges or there wiring
or will they work with the 350?
Old Apr 2, 2007 | 03:18 PM
350DREAMS's Avatar
the wiring should be str8 a few minor mods with it but u will need new injectors and ecm of course. btw when ur ready for injectors pm me my boy has some nice ones for cheap.
Old Apr 2, 2007 | 06:33 PM
coprunr's Avatar
the acdelco part # for a 5.0 and 5.7 are the same part # , i looked it up at acdelco.com
YoungDriver
Apr 14, 2009 11:05 AM
97slpss
Apr 6, 2009 09:10 PM
flyinghigh2k8
Feb 19, 2008 05:30 PM
Sassy76
May 17, 2005 03:51 PM
