TBI to carb swap-fuel pump
I put a supercharged carbed motor in my car and only have the stock in tank pump. I know this isnt sufficient, but dont have the time here to change it out. I'd like to buy the Aeromotive A1000 pump which is inline correct? Would there be a problem using this along with the in-tank pump? I just need something to keep the car running for two months until I get back to the states.
RE: TBI to carb swap-fuel pump
if the tank pump is a fuel injection pump it will be more than enough. a fuel injection fuel pump pushes around 50 psi. you will have to put a return style regulator to get the pressure down to specs. Sick
