Pump to carb fuel line
Old Mar 22, 2014 | 07:18 AM
Jonathon Thomas's Avatar
Default Pump to carb fuel line
So I had a bad fuel line from my fuel pump to my carburetor, so I bought a replacement online. It matches the original, but I can't actually get the fuel line to fit right in the car, almost like the shape is wrong or something. Is there some trick to installing one? I've never had to do it before.
Old Mar 22, 2014 | 07:38 AM
Edwardgp's Avatar
Have you tried to feed it from underneath the car, just my 2cents.
Old Mar 22, 2014 | 08:17 AM
Is it off a little bit from point a to b, or is the fitting on the carb in a totally different place? You can rebend/reshape the line, go slowly and be careful not to kink it. You probably don't have a tubing bender, so you can use a round pipe (not too small) as a guide to push and bend against.
Old Apr 2, 2014 | 01:57 AM
greencamaro1981's Avatar
its all in the fine tuning and small adjustmentd of bending in the correct spots go slow and make small adjusments
manslaughter299
Jul 24, 2012 03:17 AM
Berlinetta
82-92 V8 Tech
Nov 9, 2011 11:06 AM
Cactus
Jul 18, 2010 08:46 AM
sewerrat
Jul 6, 2008 04:15 AM
Batass
Nov 2, 2006 11:02 PM
