tbi
Old Sep 23, 2006 | 10:47 PM
cobb1985's Avatar
Default tbi
i have a 1992 camaro rs with a 305 tbi in it it has 150k miles on it but still runs stong i want to keep this motor but give it more power a friend of mine has a 305 tpi cam, crank, and the heads for it basicly he has the whole top end except for the manifold. i also have a tbi unit from a 95 350, if i put the parts on my motor will it gain power or will the parts even fit
thanks for your help
Old Sep 24, 2006 | 12:36 AM
350rs's Avatar
March 2008 ROTM
Default RE: tbi
puttin that TBI on your 305 might not work at all, computer problems may arrise. I dont know if the two TBIs are in anyway similar. Check with a dealer maybe?
Old Sep 24, 2006 | 10:09 PM
FlufyTiger's Avatar
Default RE: tbi
I would have to agree there. If that won't work, Turbocity.com sells a high flow throtle body and flow matched injector set for about $400 that's designed to bolt on to the car with no other mods, although a new dual plane carb manifold, and a TBI to 4 bbl adapter plate would really compliment the setup nicely. as it would greatly improve your airflow, if you can swing $1000 or so. Get a new exhaust system too, if you haven't already, as they change inintake flow won't deliver it's full potential if the engine can't get the added exhaust out fast enough, and a new cam will help you there too.
