starting system
Old Jan 18, 2007 | 11:17 PM
griff305's Avatar
Default starting system
i have a 92 rs when i yturn it over it doesnt want to start. starter is good. no power in the gear selector switch any ideas?
Old Jan 19, 2007 | 07:06 PM
Default RE: starting system
You need to explain this one. Does the starter spin the engine? Does the engine run? What do you mean "no power in gear selector switch"?
Old Jan 19, 2007 | 11:54 PM
griff305's Avatar
when i turn over the ignition the car wont start. I am Getting no power to the purple wire or S terminalon the solenoid.
Old Jan 20, 2007 | 12:11 AM
MadMikeZ28's Avatar
Check your fuseable links. pull on the wires, just dont look at them. Try to start it with it in neutral. Maybe the neutral safety switch. Maybe ignition switch. Do the instrument lights go out when you turn it to crank position?
Maybe your ignition switch is out of adjustment. Can you turn the key back to the accesory position?
Old Jan 20, 2007 | 12:14 AM
griff305's Avatar
ignition switch is good. there is no pwer in the neutrel safety switch and the lights dont go out. No i cant turn the key back to the ACCY
Old Jan 20, 2007 | 12:16 AM
MadMikeZ28's Avatar
did you try to turn the key back to accessory position?
Old Jan 20, 2007 | 12:17 AM
MadMikeZ28's Avatar
Then you switch is out of adjustment
griff305's Avatar
yea it dont turn back
Old Jan 20, 2007 | 12:19 AM
griff305's Avatar
the white clip with the two copper wires?
MadMikeZ28's Avatar
Do you know how to adjust it?
