Starting Problems
Old 05-22-2009, 08:40 PM
1990CamaroRS's Avatar
Fancy Sparkle
they had VATS in '89 right??? is the security light staying on for more than two seconds when you first put the key in the ignition??? VATS will disable three main components, the fuel pump, the starter or it will remove power to the injectors.
check to see if the security light stays on for more than 2 seconds. if it does, the resistor has gone bad in the security system.
EasternStryker
02-28-2010 09:57 AM
videojunkie1986
06-03-2009 06:02 PM
justingarcia947
10-08-2008 12:25 AM
KrazyHobo
11-20-2007 07:48 PM
jdubs1813
11-08-2007 01:42 PM
Quick Reply: Starting Problems
